ADmcj
8 years agoFunctional test of the FFT IP
Hi all, I would like to test the FFT IP. As such I tried to use the example that is generated with the IP parameter editor (quartus 17.1), but it generates only stuff in verilog while I need vhdl. ...
vj123
8 years agoHi,
- While Configuring parameters of FFT IP use "Generate HDL.." tab & choose VHDL under Synthesis & Simulation.
- Check output Directory path.
- Then click on "Generate"
- Use that generated .vhd file under Synthesis Directory as a design under test(DUT) in ModelSim & write a test bench for simulation if you don`t want to simulate it using TCL script.
5. If you want use Automated test bench then use NativeLink.
Best Regards
Vikas Jathar
