16 years agoFunctional questions about DSP Builder
Dear all, I have several questions for DSP Builder: 1. Can DSP Builder support triggered subsystem? 2. Does DSP Builder integrator block support external reset not by system reset? 3. ...
16 years agoThank you for replying.
For question 3, since from DSP Userguide: "Simulink issues a warning if you are using an inappropriate solver for your model.You should set the solver options to fixed-step discrete when you are using a single clock domain." "Use a fixed-step solver for a single clock domain design or a variable-step solver for multiple-clock domain designs." "To ensure correlation between the HDL and Simulink simulation, you must use a discrete fixed or variable-step solver in Simulink." But if I need to test the model in Variable-step and continues solver (i.e. ode45), can I still get the same result as discrete solver? Or even it give errors? Thanks
