16 years ago
Frame Reader Initialization
I want to implement a Frame Reader which should read data from memory and send its AVALON Video protocol to an alpha blending mixer. My clocked video output settings for PAL are:
Image Width/Active pixels: 720
Image Height/Active lines: 576
Bits per Pixel per color planes: 8
Color plane transmission format: sequence
Interlaced Video
Pixel fifo size: 720
Fifo Level at which to start output: 719
Video in and out use the same Clock
Use control port
Sync signals: Embedded in video
Active picture line: 23
Horizontal blanking: 24
F rising edge line: 313
F falling edge line: 1
Vertical blanking rising edge line: 311
Vertical blanking: 25
I have written the value 128 to all corresponding addresses of the ram. For test purposes I am using the onchip ram for this. The RAM has two masters, the NIOS II and the frame reader. The settings of the frame reader are:
Bits per pixel per color plane: 8
Number of color planes in parallel: 1
Number of color planes in sequence: 2
Maximum Image width: 40
Maximum Image height: 40
Master port width: 64
Read master FIFO depth: 64
Read master FIFO burst target: 32
Use separate clock for the Avalon MM master interface: unchecked
(The data-width of the onchip RAM is 64.)
For initialisation of the frame reader I have written the following function which is called in once the main function of my NIOS II software:
void initFrameReader()
alt_printf("Initialize Frame Reader.\r\n");
// start Frame Reader
IOWR(FRAMEREADER_BASE, 0, 1);
// Frame Select
IOWR(FRAMEREADER_BASE, 3, 0);
// Frame 0 Base Address
IOWR(FRAMEREADER_BASE, 4, ONCHIP_MEM_BASE);
// Frame 0 Words
IOWR(FRAMEREADER_BASE, 5, 800); // 40*40 / ( 64/(8*4) ) = 800
// Frame 0 Single Cycle Color Patterns
IOWR(FRAMEREADER_BASE, 6, 6400); // 40*40*4 number of pixels in the frame multiplied by the number of single cycles required to represent one pixel
// Frame 0 Reserved
// IOWR(FRAMEREADER_BASE, 7, 0); // reserved for future use ?
// Frame 0 Width
IOWR(FRAMEREADER_BASE, 8, 40);
// Frame 0 Height
IOWR(FRAMEREADER_BASE, 9, 40);
// Frame 0 Interlaced
IOWR(FRAMEREADER_BASE, 10, 8); // See VIP Processing Suite - Table 4-4
But as soon as I Activate the Layer the Frame Reader corresponds to, I do not get a valid picture. Even if I deactivate it on runtime, it does not get a valid picture anymore. I have to reset the cpu to get the alpha blending mixer get work again (with frame reader layer deactivated).
What could be the problem? I have double-checked the BSP-Editor, none of my program memory addresses are placed on the onchip-mem. Could it be an arbitration problem? As far as I know the arbitration of the sopc-builder is round-robin and only requesting masters are included in the arbitration. But I am not writing data to the onchip memory while the frame reader is reading data from the RAM.
Could someone double-check the initialisation settings of the frame reader? Did I miss something, or did I missunderstand anything?
I would be pleased if anyone can helb me.
    Hello, your post is very usful.
    I want to implement a Frame Reader which should read vide frames data from SDRAM and send its AVALON Video protocol to an Clocked video output ip to be displayed on a screen.The setting of the frame reader is :
    Number of color planes in parallel: 3
    Number of color planes in sequence: 1
    Maximum Image width: 800
    Maximum Image height: 600
    Master port width: 32
    Read master FIFO depth=Read master FIFO burst target: 64
    and read the frames from 2 memory locations.I will use the interrupt register to prevent the data lost and indicat the frame completion.
    At the begining of the siftware , i reset this register . but when reading it the interrupt register read 0 not 1.
    Is there any wrong in my software which is attached below.
    Kindly advise . Your reply will be highly appreciated.Waiting your reply ASAP
    while(1)
    alt_u32 a , interrupt , Frame0_Select , Frame0_Base_Address , Frame_0_Words , Frame_0_Single_Cycle , Frame_0_Reserved , Frame_0_width , Frame_0_height , Frame_0_progressive , Frame_0_start;
    //master port width =32(R0 byte,B0 byte,G0 byte,empty byte)
    IOWR(ALT_VIP_VFR_0_BASE, 2, 2); // reset the interrupt???????
    interrupt=IORD(ALT_VIP_VFR_0_BASE, 2);// it always red 0??????
    IOWR(ALT_VIP_VFR_0_BASE, 3, 0); // Frame0 Select
    Frame0_Select=IORD(ALT_VIP_VFR_0_BASE, 3);
    IOWR(ALT_VIP_VFR_0_BASE, 4, ALTMEMDDR_BASE);
    Frame0_Base_Address=IORD(ALT_VIP_VFR_0_BASE, 4);
    IOWR(ALT_VIP_VFR_0_BASE, 5, 480000);
    // Frame 0 Words => (640*480*3*8)/24
    Frame_0_Words=IORD(ALT_VIP_VFR_0_BASE, 5);
    printf("Frame 0 Words\n");
    IOWR(ALT_VIP_VFR_0_BASE, 6, 480000);//Frame0Single Cycle Color Patterns
    Frame_0_Single_Cycle=IORD(ALT_VIP_VFR_0_BASE, 6);
    printf("Frame 0 Single Cycle Color Patterns\n");
    IOWR(ALT_VIP_VFR_0_BASE, 7, 0); // Frame 0 Reserved Bit
    Frame_0_Reserved=IORD(ALT_VIP_VFR_0_BASE, 7);
    printf("Frame 0 Reserved Bit\n");
    IOWR(ALT_VIP_VFR_0_BASE, 8, 800);
    Frame_0_width=IORD(ALT_VIP_VFR_0_BASE, 8);
    printf("frame 0 Width\n");
    IOWR(ALT_VIP_VFR_0_BASE, 9, 600);// Frame 0 Height
    Frame_0_height=IORD(ALT_VIP_VFR_0_BASE,9);
    IOWR(ALT_VIP_VFR_0_BASE, 10, 3); // Frame 0 Interlaced => 3 = 0011
    Frame_0_progressive=IORD(ALT_VIP_VFR_0_BASE, 10);
    IOWR(ALT_VIP_VFR_0_BASE, 0, 1); //start reading
    Frame_0_start=IORD(ALT_VIP_VFR_0_BASE, 0);
    IOWR(ALT_VIP_VFR_0_BASE, 2, 2);// reset the interrupt
    a=IORD(ALT_VIP_VFR_0_BASE, 2);
    while (a&&0x02==1)
    IOWR(ALT_VIP_VFR_0_BASE, 3, 1);// Frame1 Select
    IOWR(ALT_VIP_VFR_0_BASE,11,ALTMEMDDR_BASE+0xE1000);//Frame address
    IOWR(ALT_VIP_VFR_0_BASE, 12, 480000);// Frame 1 Words
    IOWR(ALT_VIP_VFR_0_BASE, 13, 480000); // Frame 1Single Cycle Color
    IOWR(ALT_VIP_VFR_0_BASE, 14, 0);// Frame 1Reserved Bit
    IOWR(ALT_VIP_VFR_0_BASE, 15, 800);// Frame 1 Width
    IOWR(ALT_VIP_VFR_0_BASE, 16, 600); // Frame 1 Height
    IOWR(ALT_VIP_VFR_0_BASE, 17, 3);// Frame 1 progressive=> 3
    IOWR(ALT_VIP_VFR_0_BASE, 0, 1);//start reading
    IORD(ALT_VIP_VFR_0_BASE, 2);//read the interrupt register
    while (a&&0x02==1)
