16 years agoFrame Reader Initialization
Hello, I want to implement a Frame Reader which should read data from memory and send its AVALON Video protocol to an alpha blending mixer. My clocked video output settings for PAL are: Imag...
15 years agoHello, your post is very usful.
I want to implement a Frame Reader which should read vide frames data from SDRAM and send its AVALON Video protocol to an Clocked video output ip to be displayed on a screen.The setting of the frame reader is : Bits per pixel per color plane: 8 Number of color planes in parallel: 3 Number of color planes in sequence: 1 Maximum Image width: 800 Maximum Image height: 600 Master port width: 32 Read master FIFO depth=Read master FIFO burst target: 64 Use separate clock for the Avalon MM master interface: unchecked and read the frames from 2 memory locations.I will use the interrupt register to prevent the data lost and indicat the frame completion. At the begining of the siftware , i reset this register . but when reading it the interrupt register read 0 not 1. Is there any wrong in my software which is attached below. Kindly advise . Your reply will be highly appreciated.Waiting your reply ASAP while(1) { alt_u32 a , interrupt , Frame0_Select , Frame0_Base_Address , Frame_0_Words , Frame_0_Single_Cycle , Frame_0_Reserved , Frame_0_width , Frame_0_height , Frame_0_progressive , Frame_0_start; //master port width =32(R0 byte,B0 byte,G0 byte,empty byte) IOWR(ALT_VIP_VFR_0_BASE, 2, 2); // reset the interrupt??????? interrupt=IORD(ALT_VIP_VFR_0_BASE, 2);// it always red 0?????? IOWR(ALT_VIP_VFR_0_BASE, 3, 0); // Frame0 Select Frame0_Select=IORD(ALT_VIP_VFR_0_BASE, 3); IOWR(ALT_VIP_VFR_0_BASE, 4, ALTMEMDDR_BASE); // Frame 0 Base Address Frame0_Base_Address=IORD(ALT_VIP_VFR_0_BASE, 4); IOWR(ALT_VIP_VFR_0_BASE, 5, 480000); // Frame 0 Words => (640*480*3*8)/24 Frame_0_Words=IORD(ALT_VIP_VFR_0_BASE, 5); printf("Frame 0 Words\n"); IOWR(ALT_VIP_VFR_0_BASE, 6, 480000);//Frame0Single Cycle Color Patterns Frame_0_Single_Cycle=IORD(ALT_VIP_VFR_0_BASE, 6); printf("Frame 0 Single Cycle Color Patterns\n"); IOWR(ALT_VIP_VFR_0_BASE, 7, 0); // Frame 0 Reserved Bit Frame_0_Reserved=IORD(ALT_VIP_VFR_0_BASE, 7); printf("Frame 0 Reserved Bit\n"); IOWR(ALT_VIP_VFR_0_BASE, 8, 800); Frame_0_width=IORD(ALT_VIP_VFR_0_BASE, 8); printf("frame 0 Width\n"); IOWR(ALT_VIP_VFR_0_BASE, 9, 600);// Frame 0 Height Frame_0_height=IORD(ALT_VIP_VFR_0_BASE,9); IOWR(ALT_VIP_VFR_0_BASE, 10, 3); // Frame 0 Interlaced => 3 = 0011 Frame_0_progressive=IORD(ALT_VIP_VFR_0_BASE, 10); IOWR(ALT_VIP_VFR_0_BASE, 0, 1); //start reading Frame_0_start=IORD(ALT_VIP_VFR_0_BASE, 0); IOWR(ALT_VIP_VFR_0_BASE, 2, 2);// reset the interrupt a=IORD(ALT_VIP_VFR_0_BASE, 2); while (a&&0x02==1) { a=IORD(ALT_VIP_VFR_0_BASE, 2); } IOWR(ALT_VIP_VFR_0_BASE, 2, 2); // reset the interrupt IOWR(ALT_VIP_VFR_0_BASE, 3, 1);// Frame1 Select IOWR(ALT_VIP_VFR_0_BASE,11,ALTMEMDDR_BASE+0xE1000);//Frame address IOWR(ALT_VIP_VFR_0_BASE, 12, 480000);// Frame 1 Words IOWR(ALT_VIP_VFR_0_BASE, 13, 480000); // Frame 1Single Cycle Color IOWR(ALT_VIP_VFR_0_BASE, 14, 0);// Frame 1Reserved Bit IOWR(ALT_VIP_VFR_0_BASE, 15, 800);// Frame 1 Width IOWR(ALT_VIP_VFR_0_BASE, 16, 600); // Frame 1 Height IOWR(ALT_VIP_VFR_0_BASE, 17, 3);// Frame 1 progressive=> 3 IOWR(ALT_VIP_VFR_0_BASE, 0, 1);//start reading IORD(ALT_VIP_VFR_0_BASE, 2);//read the interrupt register a=IORD(ALT_VIP_VFR_0_BASE, 2); while (a&&0x02==1) { a=IORD(ALT_VIP_VFR_0_BASE, 2); } }  }
