Yuriah
9 months agoFitter cannot ...
I am trying to set up a basic SDI transmitter on an Agilex 5. Currently, my setup is a 148.5 MHz refclk, a GTS PMA Direct PHY IP configured for 12G SDI, a GTS Reset Sequencer, and a GTS System PLL co...
Yuriah
8 months agoI figured out the problem. I was trying to have an always block assign the GTS PLL refclk_rdy signal based on the positive edge of the 148.5 MHz refclk. Turns out the GTS refclk pins cannot be accessed in the main fabric.
- Wincent_Altera8 months ago
Hi Yuriah,
Just to confirm, means the problem is solved ?
IF yes, I am glad that you able to resolved it, thanks for sharing with me how you make it right.
Let me know if there is anything else I can help you.
Wincent
