17 years agoFIR Compiler 7.2 MCV Clock to compute greater than 1
Hi all,
I've been struggling with this for a while and maybe someone can shed some light on it. I am using the FIR Compiler 7.2 to create a FIR Filter that uses the MCV architecture with clocks to compute equal to 2. When the clocks to compute is 1, the filter works fine, when I change the clocks to compute to 2 (or above) the output of the filter goes to 0 and the ast_sink_ready also goes to 0. I tried both methods of multicycling (i.e. by setting ast_sink_valid manually and setting it to 1 and letting the filter figure it out) Does any one else out there have this problem? Thanks in advance!2 Replies
Let me add that I using a Cyclone II device.
I found the solution.
It seems that since I was using a clock based off of a master clock, I needed my reset to be applied longer than I thought to clear the AST buffer.
