16 years agoFIR compiler & DSP blocks
This is a bit Off-topic but, When I use the FIR compiler to produce a simple FIR, single rate, 64 coeffs, 14 bit samples, 16 bit coeffs, either single channel or two channel, the compiler doesn...
16 years agoI'm not complaining about the FIR produced. It uses few LEs and runs fast.
It is more a wonder why Altera put so much effort into including DSP blocks. Who uses them and what for? I did write my own FIR but it was hopless. The serial version had a max clk of 32MHz (in a cyclone II) and the parallel version had a max clock of 16MHz. It used a Wishbone interface. I had to convert Microchip generate coefficients from c to vhdl. Hence I upgraded to Quartus subscription.
