11 years agoFIR and CIC MegaCores Altogether
I have instantiated FIR II MegaCore as a Pulse-Shaping and upsampling by 8 filter, now I want to use CIC MegaCore after FIR to interpolate the signal... I didn't use Back Pressure feature in FIR. Simulation shows that signal is not interpolated... almost the same. In the generated test bench of the CIC IP, I noticed that input is allowed only when "in_ready" signal is high... when it's low the input is kept hold. I tried to do the same thing using Back Pressure feature in FIR IP, but because ModelSim doesn't allow mixed-HDL simulations (what a shame!) I couldn't verify. So, I used SignalTap instead... plotting the result on MATLAB shows a completely distorted signal! So... How do I use CIC along with FIR MegaCore? Can you please provide an example?
