11 years agoFIR and CIC MegaCores Altogether
Hi, I have instantiated FIR II MegaCore as a Pulse-Shaping and upsampling by 8 filter, now I want to use CIC MegaCore after FIR to interpolate the signal... I didn't use Back Pressure feature in...
11 years agoI am a bit lost between figures. (10MHz,50MHz,280,100MHz).
if your symbol rate is 50000/280 then you don't need fractinalupsampler you need to go up from 50000/280 to 100000 = 560 8 in rrc, 10 in comp filter, 7 in cic well just use a fir interpolator at 70 or two firs at 10 and 7 or rrc to go up by 56, fir by 10
