16 years agoFFT Source_valid
Hello everyone, i have some trouble with the fft core (quartus 8.1) i am using a 512 fft with streaming interface. the fft core does not give any output. after transfering some data pack...
16 years ago --- Quote Start --- finally it works, i only got it running when the "generate a clk_ena pin" is checked (in the mega wizard fft generation tool) --- Quote End --- Hi, Luis_Altera, I am having the same problem with you. Could you please tell me more specifically on where to check the "generate a clk_ena pin"? I am using Quartus II 9.0 sp2. Thanks a million!
