FFT Frequency Range
I am using the 50MHz internal clock of the Stratix III to collect samples of a chirp signal operating at 30kHz to 80kHz. I read in one of the forums that the FFT MegaCore output frequencies are 0~Fs/2 for samples 0~N/2-1, then -Fs/2~0 for samples N/2~N-1. With my 8192-point FFT, this would correspond to 0~25MHz for the first half of the samples. This means that my target range of 30-80kHz consists of only a few points. Is there any way to focus the FFT on only that range so I can get 1000+ points in the desired range? There is no clock input for the FFT MegaCore, so I cannot adjust the 50MHz clock (as far as I know). My goal is to view around1000 points of FFT data in this range using the SignalTap block. Any suggestions would be greatly appreciated.
Thanks, Cory
