Matt_P
2 years agoF-Tile Reference and System PLL Clocks IP
Hello FPGA Forum, I'm working with the IP "F-Tile Reference and System PLL Clocks Intel FPGA" IP and the 'Multi Channel DMA for PCI Express' example design. I'm trying to understand the connection...
Matt_P
2 years agoHi @ventt ,
Thanks for your reply. I've been searching through the documents provided and haven't yet cleared up my understanding.
I'm trying to understand if there's a pattern to something like the following example-
If I have a design with the 'refclk source' designated as 'refclk #3', I would expect the clock to drive the channel 3 reference pin in the F-tile, but it instead routes to the channel 2 reference pin.
Is the naming of 'refclk #3' arbitrary? Can it be renamed to 'refclk #2' to reduce confusion or mistakes?
Thank you,
