16 years agoExternal Memory
Can some one explain how to generate memory designs, allocate pins for the design and generate programming file for the design. I want the complete set of QSF file with design files. And also I want ...
16 years agoIt may, I am not sure, but your address width depends on how you are using your memory, is it a DIMM or just a single component for example?
