16 years agoExternal Memory
Can some one explain how to generate memory designs, allocate pins for the design and generate programming file for the design. I want the complete set of QSF file with design files. And also I want ...
16 years agoWrite the memory contents in .mif file format.
Allocate pins using the pin planner. Use Quartus II to generate programming files. To archive the complete set of source files, use the "archive" command in the QII menus. No you can not add a .qsf to the project, each project IS a single .qsf file, but you can merge two .qsf files into a single one. To get ASAP answers read the manuals.
