FvM
1 year agoI just reviewed the discussion and find it partly confusing and the reported result inconsistent.
Above, you are discussing a problem that the HAL layer is apparently unable to generate burst write access to GSFI IP, burst count always 1. Later Intel is quoting a four years old discussion stating that GSFI doesn't support page write. Reading GSFI reference about burst mode, I won't expect that the information still applies to recent GSFI IP versions, but it can be.
Did you try to verify in low level test if burst write is working approprately (translated to page write) or not?
