19 years agoExample DSP Builder FFT megacore V7.1
Hi all, I'm searching for a Simulink example of a application with the FFT megacore V7.1. My simulation still don't run after several hours of trying... Thank you very much! Reto
17 years agoThanks for the good demo design. Perhaps someone can help me.
I'd like to alter the design to have SOP and EOP signals generated via DSP Builder - my input digital signal will stream continuously, and the FFT will pick off 2048 points (need SOP every 1024 for maximum packet size limitation, but need EOP at 2048 points) I am having difficulty mimicking the behavior of "Pulse Generator" with the available "Single Pulse" DSP Builder block. Thank you, --Mickey
