JMa5's avatar
JMa5
8 years ago
Error Loading Design when open FFT IP core in Modelsim
Hi all,
My FFT design have a calculation length of 1024 with 16 bit wide. I set up my FFT to be streaming mode, and everything passed compilation. However, when I opened modelsim to view the result. It give me an error message: "Error: (vsim-3033) C:/Users/majin/Desktop/projects/fft_core_trial/fft_1024/synthesis/submodules/fft_1024_fft_ii_0.sv(59): Instantiation of 'asj_fft_sglstream' failed. The design unit was not found."
Does anyone have any idea about this? I am looking forward to your posts. Thank you very much!
  • Vicky1's avatar
    Vicky1
    This error occurs when missing any library or missing some instance used in design.
    1. Can you please check the 'sj_fft_sglstream' design unit is available under the top model?
    2. Can you provide your project file?(.qpf file or Go to "Project->Archive Project..")
    Best Regards
    Vikas Jathar
  • JMa5's avatar
    JMa5
    The "asj_fft_sglstream" design unit is available. That is why I am confusing about this. I have attach my project file. Thank you very much for your help!
  • Vicky1's avatar
    Vicky1
    In order to load and simulate the design successfully the following files need to be compiled in order :
    1. From the fft_1024/simulation folder - fft_024.v
    2. From the fft_1024/simulation/submodules folder –
    a. All of the _pkg.vhd files first
    b. Then the _roundsat.vhd file
    c. Followed by the rest of the .vhd files
    3. Next, compile the files in the fft_1024/simulation/submodules/mentor folder-
    a. The Verilog files (there are only 2 of them)
    b. All of the pkg files first
    c. Then the apn_* VHDL files
    d. Followed by the asj_* VHDL files -> except the asj_fft_sglstream. This one needs to be compiled last.
    e. Next compile the rest of the files auk_* VHDL
    f. Lastly compile the asj_fft_sglstream.vhd file.
    4. All of the files should be compiled successfully and you should be able to see them in the work folder.
    5. Now simulate the fft_1024_wrapper module. It will load successfully.
    Best Regards
    Vikas Jathar
