Error Loading Design when open FFT IP core in Modelsim
In order to load and simulate the design successfully the following files need to be compiled in order :
1. From the fft_1024/simulation folder - fft_024.v
2. From the fft_1024/simulation/submodules folder –
a. All of the _pkg.vhd files first
b. Then the _roundsat.vhd file
c. Followed by the rest of the .vhd files
3. Next, compile the files in the fft_1024/simulation/submodules/mentor folder-
a. The Verilog files (there are only 2 of them)
b. All of the pkg files first
c. Then the apn_* VHDL files
d. Followed by the asj_* VHDL files -> except the asj_fft_sglstream. This one needs to be compiled last.
e. Next compile the rest of the files auk_* VHDL
f. Lastly compile the asj_fft_sglstream.vhd file.
4. All of the files should be compiled successfully and you should be able to see them in the work folder.
5. Now simulate the fft_1024_wrapper module. It will load successfully.
Best Regards
Vikas Jathar
