15 years agoerror in compiling the RapidIO IP for Stratix II GX: EP2SGX90FF1508C3.
I generated the rapidio IP from the MegaWizard Plug-in Manager for the device Stratix II GX: EP2SGX90FF1508C3. It generated the codes corresponding to the parameter specified in the MegaWizard Plug-in Manager then I added all the codes generated to the quartus project. Then I compiled, during compilation the following error came Error: Can't place 730 pins with 3.3-V LVTTL I/O standard because Fitter has only 653 such free pins available for general purpose I/O placement Error: Can't place pins due to device constraints Error: Can't fit design in device Error: Quartus II Fitter was unsuccessful. 3 errors, 12 warnings Error: Peak virtual memory: 432 megabytes Error: Processing ended: Wed Mar 09 15:29:40 2011 Error: Elapsed time: 00:00:29 Error: Total CPU time (on all processors): 00:00:29 Error: Quartus II Full Compilation was unsuccessful. 5 errors, 36 warnings I am new to Quartus software please help me in solving this error.......2 Replies
Your design is using to many input/output ports on the FPGA. Try to reduce them. 730 ports is a lot...
Thank you for your advice I regenerated the IP using MEGA WIZARD with the different parameter and recompiled the design successfully :)
