Длаза's avatar
Длаза
6 years ago
Error (14566): The Fitter cannot place 2 periphery component(s) due to conflicts...
Hi,guys!
Today I am building a DDR4 project using the Arria10 EMIF Interface. When I configured the project for DDR4-2400R LRDIMM x72, I generated an example that contains two traffic generators, two Arria10 EMIF Interfaces, although I specified 1 DIMM in the settings. This is my first project with DDR4, so I connected the second LRDIMM to the emif_1_slave module.
When compiling, fitter indicates errors:
Error (14566): The Fitter cannot place 2 periphery component (s) due to conflicts with existing constraints (1 OCT calibration block (s), 1 REFCLK_GROUP (s)).
Error (175020): The Fitter cannot place logic OCT calibration block that is part of Arria 10 External Memory Interfaces ed_synth_altera_emif_180_kgljw4i in region (78, 168) to (78, 171), to which it is constrained, because there are no valid locations in the region for logic of this type.
Info (14596): Information about the failing component (s):
Info (175 028): The OCT calibration block name (s): ed_synth: ddr4_lrdimm | ed_synth_altera_emif_180_kgljw4i: emif_0 | ed_synth_altera_emif_arch_nf_180_r4boqsy: arch | ed_synth_altera_emif_arch_nf_180_r4boqsy_top: arch_inst | altera_emif_arch_nf_oct: oct_inst | cal_oct.powerup_oct_cal.termination_inst
Error (16234): No legal location could be found out of 1 considered location (s). Reasons why each location could not be used are summarized below:
Info (175015): The I / O pad ddr4A_oct_rzq_i is constrained to the location PIN_F25 due to: User Location Constraints (PIN_F25)
Info (14709): The constrained I / O pad is contained within a pin, which is contained within this OCT calibration block
Error (175006): Could not find path between the OCT calibration block and destination pin
Info (175027): Destination: pin ddr4B_ba_o [1]
Info (175015): The I / O pad ddr4B_ba_o [1] is constrained to the location PIN_N9 due to: User Location Constraints (PIN_N9)
Info (14709): The constrained I / O pad is contained within this pin
Error (175022): The OCT calibration block could not be placed in any location to satisfy its connectivity requirements
Info (175021): The pin was placed in location N9
Info (175029): 1 location affected
Info (175029): TERMINATION_X78_Y168_N6
Please help me remove the error and understand why Quartus generated two traffic generators and two EMIF cores
