9 years agoEMIF core clock sharing problem
Hi, I'm trying to connect two EMIF QDRII controlers with shared clock on arria 10 (hard PHY and Soft Controller). I had generated EMIF slave component and connected it "clks_sharing_slave_in" t...
8 years agoIn the newer QII version like 17.0. Once you turn on the core clock option, it will disable the pll_ref_clk pin for slave component. This mean the pll_ref_clk also will connect internally through the mater-slave connection. So, you will not see this type of conflict anymore.
