DSP Builder license
hi i have cyclone II kit EP2C70 with quartus II, dsp builder and nios II all v6.0.
i download .dat file from the licensing site of altera. my quartus II issue is resolved with that file. but when i run signal compiler from dsp builder. then messages appear in the "signal compiler messages window" that "unable to check a valid DSP Builder license". when i run synthesis then quartus II analysis & Synthesis remain unsuccessful.. what i should do? i need suggestion18 Replies
I think so. What's probably happening is that DSP Builder is actually using your 10.0 quartus version but you should make sure that the Quartus directory on your Windows path points to the 10.0, or you may find there are DLL linking problems. That may be the cause of your problem.
Sorry i have been working on this problem for 2 days and my mind isn't with it anymore. What do you mean sir? i am going to downgrade my quartus 10.1v (uninstall it) to 10.0v so dsp_builder 10.0v can work like you said. Therefore, all the software should be compatiable (including matlab R2008). Then use my licese.dat
Yes, I'm saying downgrade your quartus.
I'm not saying it will fix your problem, but even if you could get your license problem to go away, DSP Builder 10.0 would not generate correctly with Quartus 10.1. - Altera_Forum
my license error is still occuring. what can i do to fix this?
Did you update LM_LICENSE_FILE after downgrading? You had your license file at C:\altera\10.1sp1\license.dat before. Does that still exist?
Unfortunately I can't think of any other reason why your license file might fail. - Altera_Forum
I didn't know the versions had to be the same. Pretty sure I've used different versions together in the past.
It's not been possible to mix versions since before 7.1. You could use the generated HDL from one version (using HDL Export) and add that to a project which you compiled with a different version of Quartus. DSP Builder is installed directly into quartus and can only be installed into a version that's the same as it.
--- Quote Start --- Hi, I have this problem also. I have a Valid license. Environment variable is set correctly. Open quartus ii\licence_setup... and in there i see all the vendors INCLUDING C4D5. Typed this command in matlab: dos('lmutil lmdiag C4D5_512A') i get : lmutil - Copyright (c) 1989-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved. FLEXnet diagnostics on Wed 4/27/2011 19:10 ----------------------------------------------------- License file: C:\altera\10.1sp1\license.dat ----------------------------------------------------- "C4D5_512A" v2035.12, vendor: alterad uncounted nodelocked license, locked to ethernet address "0013720d801f" no expiration date This is the correct node for this node-locked license ----------------------------------------------------- ans = 0 all seems fine untill i try to compile using signal comipler, i get this error: Matlab Error Unable to obtain a DSP Builder license. Please check that your LM_LICENSE_FILE environment variable is set to a valid license file or license server. LM_LICENSE_FILE is currently "C:\altera\10.1sp1\license.dat". Error: Error during compilation: Error: Error analyzing model see log for details. Im using quartus 10.1, dsp builder 10.0, matlab R2008b. Stratix ii dsp kit. PLEASE PLEASE PLEASE HELP. Regards, Husam --- Quote End --- may i ask you that how you get you dsp builder license? thank you ...
