15 years agoDSP Builder license
hi i have cyclone II kit EP2C70 with quartus II, dsp builder and nios II all v6.0. i download .dat file from the licensing site of altera. my quartus II issue is resolved with that file. but w...
15 years ago --- Quote Start --- Hi, I have this problem also. I have a Valid license. Environment variable is set correctly. Open quartus ii\licence_setup... and in there i see all the vendors INCLUDING C4D5. Typed this command in matlab: dos('lmutil lmdiag C4D5_512A') i get : lmutil - Copyright (c) 1989-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved. FLEXnet diagnostics on Wed 4/27/2011 19:10 ----------------------------------------------------- License file: C:\altera\10.1sp1\license.dat ----------------------------------------------------- "C4D5_512A" v2035.12, vendor: alterad uncounted nodelocked license, locked to ethernet address "0013720d801f" no expiration date This is the correct node for this node-locked license ----------------------------------------------------- ans = 0 all seems fine untill i try to compile using signal comipler, i get this error: Matlab Error Unable to obtain a DSP Builder license. Please check that your LM_LICENSE_FILE environment variable is set to a valid license file or license server. LM_LICENSE_FILE is currently "C:\altera\10.1sp1\license.dat". Error: Error during compilation: Error: Error analyzing model see log for details. Im using quartus 10.1, dsp builder 10.0, matlab R2008b. Stratix ii dsp kit. PLEASE PLEASE PLEASE HELP. Regards, Husam --- Quote End --- may i ask you that how you get you dsp builder license? thank you ...
