--- Quote Start ---
Hi, I have this problem also. I have a Valid license. Environment variable is set correctly. Open quartus ii\licence_setup... and in there i see all the vendors INCLUDING C4D5.
Typed this command in matlab: dos('lmutil lmdiag C4D5_512A')
i get :
lmutil - Copyright (c) 1989-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
FLEXnet diagnostics on Wed 4/27/2011 19:10
License file:
C:\altera\10.1sp1\license.dat -----------------------------------------------------
"C4D5_512A" v2035.12, vendor: alterad
uncounted nodelocked license, locked to ethernet address "0013720d801f" no expiration date
This is the correct node for this node-locked license
ans =
0
all seems fine untill i try to compile using signal comipler,
i get this error:
Matlab Error
Unable to obtain a DSP Builder license. Please check that your LM_LICENSE_FILE environment variable is set to a valid license file or license server. LM_LICENSE_FILE is currently "
C:\altera\10.1sp1\license.dat".
Error: Error during compilation: Error: Error analyzing model see log for details.
Im using quartus 10.1, dsp builder 10.0, matlab R2008b. Stratix ii dsp kit.
PLEASE PLEASE PLEASE HELP.
Husam
--- Quote End ---
may i ask you that how you get you dsp builder license? thank you ...
