16 years agoDSP builder compilation error
Hi, I am working on a project and have just started using dsp builder. I am currently facing a problem while compiling the model in the complier. it shows that its compiling, but nothing happe...
16 years agoMeans it's not set. Was a long shot. If this variable was set it could make Java stall on startup waiting for a debugger to attach. It's irrelevent anyway if you see no Quartus process running in the task manager.
One other thing you could do is make sure that Quartus is on your windows path, although I would have thought DSP Builder would give an error if it couldn't find it.
