18 years agoDSP builder - loading and indexing a vector
Hi I'm using the DSP builder in Simulink (Matlab), where I am implemeting a split-radix FFT. I would like to load in a vector from my workspace and then adress each element in the vector as I ...
16 years ago --- Quote Start --- Thanks for the answer Yes I tried with LUTs, but the problem is that I can not write the result, I obtain after processing the loaded values, back into the LUTs. I have made an implementation where I use a combination of multiplexers, demultiplexers and Single Port RAM. It is complicated but it works! --- Quote End --- Hello i am having the same issue. I am using the FFT block and generate the controller and everything, the problem is that I would like to stroe the data on the DE2board. I satrted using the RAM block from the storage library with its controller I designed and works. However, I ahve problems when compiling the model. I have a fit error I think it is because my the data I am using has more memory than the M4K memory chip. So I was thinking to stored the info in a SDRAM but do you konw guys how can I do this form DSP builder?? or how can I do it in SOPC nad thne import it into my Simulink model using HDL import block? Please any help is useful thanks!! ismagine
