SWinc's avatar
SWinc
8 years ago
Documentation on MAX10 fiftyfivenm_rublock command
I am looking for the documentation that describes the protocol used to update CFM0 / CFM1&CFM2. UG-M10CONFIG mentions the fiftyfivenm_rublock, but I can not seem to find any documentation that describes the correct sequence of events to update the configuration memory.
Any help would be greatly appreciated.
Thank you,
Sam
  • Nooraini_Y_Intel's avatar
    Nooraini_Y_Intel
    Hi Sam @SWinc (Customer)​,
    The fiftyfivenm_rublock is use in the Dual Boot IP to perform configuration (to switch) between image 0 and image 1 store in the CFM0 and CFM1/2 memory block respectively. You can refer to figure 3 under chapter "2.2.1. Remote System Upgrade" which only shows the process to switch between image 0 and image 1.
    Nooraini
    • jozephka99's avatar
      jozephka99
      So, we have to use this block if we want to RSU through user logic. But there is no documentation about this. How can we exactly build a user logic to perform RSU. Also this fiftyfivenm_rublock is in verilog. How can we implement this into VHDL.
