SWinc
8 years agoDocumentation on MAX10 fiftyfivenm_rublock command
Hello, I am looking for the documentation that describes the protocol used to update CFM0 / CFM1&CFM2. UG-M10CONFIG mentions the fiftyfivenm_rublock, but I can not seem to find any documentation th...
Nooraini_Y_Intel
8 years agoHi Sam @SWinc,
In order to update the CFM0 and CFM1/2 memory block, you need to use the On-Chip flash IP. The fiftyfivenm_rublock does not function to access CFM or UFM memory block in the MAX 10. You can refer to the MAX 10 User Flash Memory user guide for the details on the On-Chip Flash IP protocol.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_ufm.pdf
Nooraini
