SWinc
8 years agoDocumentation on MAX10 fiftyfivenm_rublock command
Hello, I am looking for the documentation that describes the protocol used to update CFM0 / CFM1&CFM2. UG-M10CONFIG mentions the fiftyfivenm_rublock, but I can not seem to find any documentation th...
Nooraini_Y_Intel
8 years agoHi Sam @SWinc (Customer),
The fiftyfivenm_rublock is use in the Dual Boot IP to perform configuration (to switch) between image 0 and image 1 store in the CFM0 and CFM1/2 memory block respectively. You can refer to figure 3 under chapter "2.2.1. Remote System Upgrade" which only shows the process to switch between image 0 and image 1.
Nooraini
jozephka99
Contributor
5 years agoSo, we have to use this block if we want to RSU through user logic. But there is no documentation about this. How can we exactly build a user logic to perform RSU. Also this fiftyfivenm_rublock is in verilog. How can we implement this into VHDL.
