11 years agoDisplayPort IP Sink - Spread Spectrum Clocking
Hey can anyone comment if the Altera displayport receiver (sink) IP core supports spread-spectrum clocking, by the display port source, of the incoming video lanes?
Thanks!2 Replies
Are you looking at the Bitech Displayport IP core.
I don't know for sure, but this should be more of a function of the FPGA PLL than the logic core. Basically can the core PLL maintain lock when the input clock is spread. I would check the specific family of FPGA handbook and check the PLL capablilites. I know SATA also can use spread spectrum clocking, and some families for FPGA are ok with this while others are not. Pete - Altera_Forum
Anakha, thank you. Per your suggestion I began review of the Arria data. It does appear Arria family Giga bit receiver PLLs have capability to accept the extra jitter from SSC. Also appears that PCI-e transmitters can use SSC, similar to the DisplayPort spec, and Arria devices appear to have good PCIe support. So gonna take a bit more research but looks promising. Yes the Bitec core as well as the Altera core are under consideration for our solution. --kb
