16 years agoDecimatio FIR filter in FPGA
Hi, I was required to build a decimation filter using FIR filter (CIC filter cannot be used). I used FIR compiler to implement the decimation filter. The sampling frequency of ADC is 120 MHz, and I n...
16 years agoThe problem seems that the FIR compiler implement downsampling before filtering. I use the same coefficients but let filters be single rate. Then I downsample the filter output by myself. I can get the right results. I'm wondering whether there is something wrong when I use FIR compiler to implement decimation filter.
