16 years agoDecimatio FIR filter in FPGA
Hi, I was required to build a decimation filter using FIR filter (CIC filter cannot be used). I used FIR compiler to implement the decimation filter. The sampling frequency of ADC is 120 MHz, and I n...
16 years agoThanks, kaz. You mean the least cutoff freq should be no less than 1.25 MHz. If I would like to have the cutoff freq to be 1 MHz, then I should have another single rate FIR filter in the following. Is that right?
Does the requirement for cutoff freq also suit for the 1st decimation fir? I mean the cutoff freq for the 1st decimation FIR should also be no less than 1.25 MHz?
