16 years agoDecimatio FIR filter in FPGA
Hi, I was required to build a decimation filter using FIR filter (CIC filter cannot be used). I used FIR compiler to implement the decimation filter. The sampling frequency of ADC is 120 MHz, and I n...
16 years agoassuming the cutoff is adequate then a possible area to cause spur is overflow of output data in your filter leading to wrapping up of results.
your cutoff must be at least 0.5*1/48 of 120MHz = 1.25MHz
