anonimcs
Contributor
2 years agoDDR4 EMIF IP Inquiry for Arria 10
Dear A10 DDR4 EMIF IP Owners, I have a design on Quartus 21.3 Pro and I noticed that the External Memory Interface IP for DDR4 memory has some timing violations within the IP core. I would expect th...
anonimcs
Contributor
2 years agoSorry for the late reply. Do you mean that I should change pll_ref_clk and oct_rzqin's pin constraints so that they need to be in IO Bank 2K for HPS and 3B for FPGA instead of 2J and 3A respectively ?
I'm attaching my current constraints (converted to txt) for HPS and FPGA here. Looking forward to your response.
Kind regards
anonimcs
Contributor
2 years ago@AdzimZM_Intel @WeiHanT_Intel any comments ?
- AdzimZM_Altera2 years ago
Hi @anonimcs
According to the ddr4.txt, IO Bank 2K for HPS and IO Bank 3B for FPGA are the Address and Command group.
You should place the pll_ref_clk and oct pins in that IO Bank.
Adzim
