11 years ago
DDR3_CONTROLLER problem
There is an error when I complie the DDR3 controller simulation design:
Error (17044): Illegal connection found on I/O input buffer primitive DDR3_example_sim_e0:e0|DDR3_example_sim_e0_if0:if0|DDR3_example_sim_e0_if0_p0:p0|DDR3_example_sim_e0_if0_p0_acv_hard_memphy:umemphy|DDR3_example_sim_e0_if0_p0_acv_hard_io_pads:uio_pads|DDR3_example_sim_e0_if0_p0_altdqdqs:dq_ddio[0].ubidir_dq_dqs|altdq_dqs2_acv_connect_to_hard_phy_cyclonev:altdq_dqs2_inst|strobe_in. Source IO DDR3_example_sim_e0:e0|DDR3_example_sim_e0_if0:if0|DDR3_example_sim_e0_if0_p0:p0|DDR3_example_sim_e0_if0_p0_acv_hard_memphy:umemphy|DDR3_example_sim_e0_if0_p0_acv_hard_io_pads:uio_pads|DDR3_example_sim_e0_if0_p0_altdqdqs:dq_ddio[0].ubidir_dq_dqs|altdq_dqs2_acv_connect_to_hard_phy_cyclonev:altdq_dqs2_inst|obuf_os_0 also drives out to other destination than the buffer.
The error points to the following code:
if (DIFFERENTIAL_CAPTURE_STROBE == "true")
begin
cyclonev_io_ibuf
.differential_mode(DIFFERENTIAL_CAPTURE_STROBE),
.bus_hold("false")
) strobe_in (
.i(capture_strobe_ibuf_i),
.ibar(capture_strobe_ibuf_ibar),
.o(dqsin),
.dynamicterminationcontrol(1'b0)
end
else
begin
cyclonev_io_ibuf
.bus_hold("false")
) strobe_in (
.o(dqsin),
.ibar(),
end
Have anyone meet this error before?
1 Reply
