16 years agoddr2 tco skew to high?
I generated a ddr2 controler with cyclone2 ip core.
when i full complation used quartus2 7.2, it warning TCO skew between clock to sdram pins too high at 135ps. how to solve it? THANK YOU !2 Replies
The simple answer is to manually place the clk output pins. They all need to be on the same type of pin, differential clock output pairs are a good choice
thank you,my clock already is differential clock,and the clock pin was generated by the IP core
