16 years agoddr2 sdram
Hello, I'am new to SOPC build,and sorry for my poor english. I have bought a dsp development kits from alter,and there is an ddr2 sdram on this development board. this is the development kits I...
16 years agoI am happy to tell you that I am using the same board that you have!
Anyway, to deal with old versions you would only open the SOPC Builder and chose to upgrade the design and then continue using your version normally. Tell me what assignment did you use for the DDR2 pins? I think that you assigned them using the ep2c70f672 board location while you must use the original ddr2 core location (Refers to the reference manual of the board.) I again recommend to use the standard design which comes with the board documents (<..>\Kits\CycloneII_DSP_Kit-v6.0.1\Examples\NiosII\example_designs\verilog). The design has its correct assignment and any other parametrization.
