16 years agoDDR2 highperformance controller local_init_done, s_tracking_setup deadlock
Dear all, I'm using DDR2 hp memctrl IP within Stratix III, addressing 2 parallel HYB18T1G160C2F-3S (totaling to 32-bit data bus width), phy_clk = 200 MHz I'm currently facing the issue, ...
16 years agoHi Peter,
I don't have a Stratix III Dev kit with me right now. From the temperature case which you described, it confirms my suspect on calibration failure. - May I know which version of Quartus are you using? - Also, you might want to try out the ALTMEMPHY Debug Kit: w_w_w.altera.com/literature/hb/external-memory/emi_debug_hw.pdf?GSA_pos=1&WT.oss_r=1&WT.oss=altmemphy%20debug%20RAM (See chapter 4, sorry couldn't post links cause I don't have enough post counts, replace "w_w_w" with "www") Most probably your problem is caused by "resynch clock phase", but those are only my guesses. p/s: you'll have to look at the non-leveling calibration portion because this is DDR2. Hope that helps.
