16 years agoDDR2 highperformance controller local_init_done, s_tracking_setup deadlock
Dear all, I'm using DDR2 hp memctrl IP within Stratix III, addressing 2 parallel HYB18T1G160C2F-3S (totaling to 32-bit data bus width), phy_clk = 200 MHz I'm currently facing the issue, ...
16 years agoIf I understand your problem correctly, the PHY calibration doesn't always pass, thus the low local_init_done signal.
I have some question: - Is this hardware/simulation? - If this is hardware, I assume that in one compilation flow, calibration doesn't always pass. Am I correct? - If yes to above question, this is most probably calibration timing problem. Then you'll have to look at TimeQuest report, does your design pass timing marginally? Hope that helps.
