DDR2 clock from PLL out
I am using Arria ii gx FPGA in Nios processor.altmemphy IP and our board main clock is 50 mhz
i want to know about interfacing between DDR2 clock to FPGA
my customize board connected the DDR2 clock with the differential pair pin AJ16 and AJ15.
My question is about the PLL dedicated pin how to create or assign dedicated pin in my top level design
Nome
- EBERLAZARE_I_Intel
Can you use this design to see the connection and use it as template for your board? You may remove other IP that you're not using and update the top level after:
Maybe you can also share your design?
Can you check my previous post?
Try use this design to see the connection and use it as template for your board. You may remove other IP that you're not using and update the top level after:
- nome
Hello
Thanks for your comments
I have custom board can't change any ddr2 inclock pins because its own old nios processor working excellent
we are still facing critical warnings from pll inclk
please help us
nome
