nome
2 years agoDDR2 clock from PLL out
hello I am using Arria ii gx FPGA in Nios processor.altmemphy IP and our board main clock is 50 mhz i want to know about interfacing between DDR2 clock to FPGA my customize board connected the DD...
EBERLAZARE_I_Intel
2 years agoHi,
Try use this design to see the connection and use it as template for your board. You may remove other IP that you're not using and update the top level after:
- nome2 years ago
Hello
Thanks for your comments
I have custom board can't change any ddr2 inclock pins because its own old nios processor working excellent
we are still facing critical warnings from pll inclk
please help us
nome
