16 years agoDDR SDRA IP local address
I try to use DDR SDRAM IP controller. I need it for 1 Gbyte DDR memory. after setting the block and the controller sign that we have 1 Gbyet memory we only get 26 address line, and we need 27 ad...
16 years agoWhat configuration are you using? For example a 1GB RAM that has a x32 off-chip interface in half-rate mode will be x128 on the local side. That will result in 26 address lines. That same memory in full-rate mode will appear as a x64 on the local side and expose 27 address lines.
