Cyclone 10 GX Dev Kit: IOPLL not locking when using CvP mode
Hi Farabi,
Thanks for your help. I believe I’ve identified the root of the problem. I noticed that the Cyclone 10 GX FPGA series only supports CvP initialization mode (one-time configuration via PCIe after power-up), but not the CvP Update mode (reconfiguration during runtime).
This limitation seems to be a plausible explanation for the system behavior I’ve been observing. I found this information mentioned here:
https://community.intel.com/t5/FPGA-SoC-And-CPLD-Boards-And/Cyclone-10-GX-CvP/m-p/1326978#M21253
What do you think?
Also, I’ve been wondering how to verify that a peripheral image *.periph.jic and a core image *.core.rbf are compatible with each other.
Is there a tool in Quartus Prime that can help with this?
As far as I can tell, a simple binary comparison of the peripheral images from two different FPGA builds doesn’t seem sufficient to check compatibility.
Thank you in advanced
