16 years agoCVO frequency
I have a design that uses a CVO. This is in a Stratix III part. The User Guide states that the CVO should be able to run around 271 - 317MHz depending on it's configuration. I'm able to approach t...
16 years agoi misunderstood i thought you were targeting 1080p. i know someone going over 1080p as well, i'll ask how they approached the problem. you may need to build a CVO in this case
and i think CVI and CVO are the only VIP blocks with .sdc files, the rest should be in the SOPC .sdc
