16 years agoCVO frequency
I have a design that uses a CVO. This is in a Stratix III part. The User Guide states that the CVO should be able to run around 271 - 317MHz depending on it's configuration. I'm able to approach t...
16 years agoI added in the .sdc for the CVO and my worst case slack went from -1.468 to -0.259. So that's quite an improvement. Still not where I need to be but much closer. Sorry the .bmp doesn't show up very well.
From Node: tx:InstTx|VipCvo:the_VipCvo|VipCvo_GN:auto_inst|alt_vip_IS2Vid:vipcvo|alt_vip_common_generic_count:v_counter|count[10] To Node: tx:InstTx|VipCvo:the_VipCvo|VipCvo_GN:auto_inst|alt_vip_IS2Vid:vipcvo|reset_counters Is the worst case path.
