16 years agoCVO frequency
I have a design that uses a CVO. This is in a Stratix III part. The User Guide states that the CVO should be able to run around 271 - 317MHz depending on it's configuration. I'm able to approach t...
16 years agoAlso - so I need to add a path for the .sdc for every IP that I use? I guess I assumed this would be automatic.
