16 years agoCVO frequency
I have a design that uses a CVO. This is in a Stratix III part. The User Guide states that the CVO should be able to run around 271 - 317MHz depending on it's configuration. I'm able to approach t...
16 years agodid you add the .sdc constraints file for the CVO from $QUARTUS_ROOTDIR/../ip/altera/clocked_video_output? there are some false paths that may help timing
can you paste the first couple failing paths?
