16 years agoCVO and PAL - How?
Hi all, I am trying to generate a PAL video output using the VIP suite. At the moment my device (A cyclone 2c35) only has the test pattern generator and the clocked video output. I...
16 years agoAre you trying to do a true composite PAL signal? For that you need more than a simple video DAC. Or are you just trying to do an RGB or YPbPr component output at 576i?
In either case, your timings seem a bit off. For a 576i signal with a pixel clock of 13.5 MHz, the usual total frame size is usually 864x625 (864 * 625 * 25 = 13.5M). One thing to check is if your DAC supports a pixel clock as low as 13.5 MHz. I have seen video encoders which require at least 27 MHz.
