17 years ago
CRC Compiler Settings
Hey, I am trying to use the CRC compiler to verify the CRC for the MAC level of ethernet. I am unable to simulate a version that matches an actual message. The Altera documentation does not provide any hint of the right configuration. I am using it with a 32-bit word input.
    I figured out the proper settings, see below. This is for byte wide input.
    Number of channels: one
    Datapath: 8 bits
    Symbols per word: one
    Process low-numbered bit in each symbol first: check
    Processing low-numbered symbols first: not checked
    Select: CRC-32
    Starting value: 1's
    Number of leading bits ignored in the first word: 0
    Negate checksum: Check
    Bit-swap checksum: Check
    I am trying to integrate CRC-CCITT into my Cyclone III design. It synthesizes etc fine but if I add the input and outputs of the core to my SignalTap design, I start getting instance mismatch error, i.e., 'Not compatible with the device'. Could someone please shed light on why this may be happening. Just to clarify, the FPGA is in un-tethered mode (its on a board with no internet access).
