17 years agoCRC Compiler Settings
Hey, I am trying to use the CRC compiler to verify the CRC for the MAC level of ethernet. I am unable to simulate a version that matches an actual message. The Altera documentation does not provide a...
17 years agoI figured out the proper settings, see below. This is for byte wide input.
Number of channels: one Datapath: 8 bits Symbols per word: one Process low-numbered bit in each symbol first: check Processing low-numbered symbols first: not checked Select: CRC-32 Starting value: 1's Number of leading bits ignored in the first word: 0 Negate checksum: Check Bit-swap checksum: Check
